24T vs 58T Reluctor
MrE
You cannot use a 58x wheel and 4x timing set on an 0411 computer unless you condition the signal between the two with a lingenfelter style box.
You can run afm on an early gen4 E40 24x computer not an 0411 though. Maybe vvt also but i would have to check on that.
If you are looking for a cleaner signal as ive seen some complain about then use an aftermaket system or run it off an ati balancer hub. There are a few kits that allow you to do that....although ive seen 24x vehicles blow past 8k without an issue on the waveform or signal from the reluctor. Im just assuming thats why you would want to do that.
Is there some other reason youd want to do that?
Thanks for the info, sorry it won't work for me.
MrE
We have a better option. we do offer billet 24x wheels. they are a much better option and do not need to be tack welded in place either. their tolerance is within a tighter spec than gm as far as crank flange interference and straighteness.
If you are interested please let me know
MrE
I saw one most recently on a friends Turbo motor recently. The wheel started to separate where they are pressed together and friction welded.
I recommend you weld those area's as well
