PID for Knock on 0411 ECM
Any clue which 'display type' is the one that displays Max and Min values? I just now ran through adding a new display and the type that does that doesn't jump off the screen...
Thanks,
-Kyle
edit - the "Half Dial (Meter)" would also work, they're basically the same except the display type used, ones a needle the other uses a bar/meter
It turns out, that if I 'long press' the current display I get an option to set Min and Max values that I don't think were offered while setting up the display, so I edited that way. Is there a reason to set a MIN value?
This is all great and everything and I'm super glad that this is able to be read now, but, it seems to be indicating to me that Knock is not the reason my power sucks off-throttle. The last logs that were reviewed here on LS1Tech showed about 9 degrees of retard. If it's not coming from Knock, where is it coming from?
I'm about to drive back in towards town to get my mountain bike out of the shop (because it hasn't been warm enough to ride up 'til now?), so I'll give these gauges and logs a thorough workout.
Thanks,
-Kyle
Thanks,
-Kyle
It doesn't seem to show any Spark Retard, but don't let that fool you! It's still running like ...it's running poorly...
-Kyle
