PID for Knock on 0411 ECM
I'm hoping someone with HPTuners and a 0411 can extract it from the software.
I'm trying to chase down some (hopefully) false knock and a 'monitor' would probably be quite helpful.
Supposedly the 0411 can read several different Knock PID's, but I've never been able to get it working on my Android/ELM Scan Tool.
Any help would be VERY much appreciated!
Thanks,
-Kyle
PID: 2211a6
scale factor x1
equation: (22.5*A)/256
auto
I dunno if this is what you're looking for.
edit- if you have the PID and equation for IDC that'd you can provide that'd be great!
Didn't work... I tried the 'Alternative' PID, too.
None of the 3 Knock PID's in Toque seemed to do anything. The 11a6 said no data received in OBDLink. Didn't try 125d in OBDLink, but it registered a constant -1 degree in Torque.
The Knock Sensor never moved in the short drive I tested it with.
Do these work on your 0411?
Does this help with IDC?:
IDC is not a scale of x pulsewidth is y duty cycle. It is a calculation. I don't know how you'd set it up in EFI Live, but it's a given custom PID in HP Tuners.
IPW = injector pulse width in ms
RPM = engine speed
IDC = injector duty cycle
IDC = (IPW * RPM) / 120,000
17ms at 6500rpm is 92%.
From here:
https://www.corvetteforum.com/forums...ssure-too.html
-Kyle
So, it turns out that I do get data on these 3 Knock PID's sometimes.
Any idea why it might not be always reporting?
If, for instance, the wire from one or both Knock Sensors had a bad wire, would the data report 'no data'? It seems like it should just report 0.
I don't have any real reason to suspect my wiring, but I guess I'll have to check it now. I'm attaching a couple .csv logs from Torque if anybody would like to look them over and maybe give some feedback.
I guess I should start another thread on this old truck...
Thanks,
-Kyle
...and I'd just stop logging the other 2 fields "[GM]Knock Retard(Alternative)(Deg.)" and "[GM]Knock sensor active counter(Count)"
I guess sitting at 0 is actually what I want, but I'm trying to figure out why I get bunch of timing retard just off throttle...see one of my other threads on this old truck...
Thanks!
-Kyle
-Kyle
also might as well move the KR degree parameter to a new window and include other parameters such as RPM, throttle %, timing adv, and anything else you may want to add.
