Help on best approach to basic tuning
( stay away from oiled air filter )
Stay with the original factory (screened) MAF;
you're basically stock so there's not much to tune to;
replace your front O2 sensors (they would be too old by now);
replace anything else that needs to be (spark plugs and wires, fuel filter);
( replace worn out suspension joints/bushings, this makes a big difference )
make sure your PCV is not causing oil to be sucked in;
Sounds like you want to go with a handheld (like Diablo), it lets you adjust WOT timing and fuel in a narrow range, and a few other things...
with the stock thermostat, you probably should lower the fan temps a bit, the factory sets them too high.
$0.02
