removing o2 sensors...
anyway good thing there are tons of help out there but im having trouble deciding whether or not to keep front o2 sensors
its going to be a track car
i will be running wideband
are they only to do with fueling?
pros cons of keeping them
The car will run without O2 sensors. You will just have to run and tune it in open loop. O2s are just used for idle and part throttle closed loop fuel trimming. Even for a street car while having O2s will be easier to tune you can, and many do run open loop with out them. And for a track car, even if you had them they are not used for WOT fueling at all. Flat out racing? Sure, then you don't need O2 sensors. AND I noticed the OP IS running it at the track, so my bad there. It was early in the AM.... lol
I go there again because I'm right. The car WILL run without O2 sensors, but not nearly as well as with. They're there for a reason.
I SHOULD have said, "the front O2 sensors are needed to fully define the A/F ratio." So there.
