No power on pin 57 help please
Im assuming you mean Pin57 Constant battery power. If you dont have power here then its an issue with the harness. Youll have to trace this wire out and find where its broken. Double check fuses first.
Pin 19 should only have power when the key is in start or run.
http://www.lt1swap.com/pictures/1_power_ground.gif
