Crank position sensor relearn
Old Jun 30, 2004 | 11:53 AM
Bill's 02 Z-28 SS's Avatar
Default Crank position sensor relearn
Hi Guys
I have question - I replaced my Cam and have been tuning my PCM (slowly). I was reading some old postings and somebody stated that you should perform a Crank position sensor relearn after replacing the Cam and doing tuning. When I have not done that and was wondering if I should do it or leave well enough along?
Thanks
Bill
Old Jun 30, 2004 | 04:26 PM
Bad30th's Avatar
The ECM will let you know if it can't learn the crank position - it will throw a code P1336 "Crankshaft Position System Variation Not Learned".
If you have no code, you shouldn't need to worry.
BTW - only a Tech II tool (dealer) or newer verions of EFILive software can do the CASE relearn as far as I know.
Normally it only needs to be done when replacing the PCM or the crank reluctor/sensor.
Bad30th
Old Jun 30, 2004 | 06:00 PM
monodax's Avatar
Bad30th
HP Tuners is adding that feature pretty soon. It is one of those things people wanted and they are adding.
Old Jul 1, 2004 | 08:31 AM
Default Thanks
Thanks - I have the latest version of EFILive, so I could do it but there are no codes. I will leave well enough alone.
Bill
Old Jul 1, 2004 | 12:08 PM
ataylors's Avatar
You can also do this with some models of Snap On scanners, you can rent ti at Pep Boys.
