Timing changing, not sure why
Dave
Dave
This is of course unless you have a pcm unlike anything ive ever seen
1. If I have my HOT table the same as my Idle table I will have a fairly high idle table
2. and then from 1200 to 1600 In the idle table I have to do some signifigant smoothing. Actually my HOT table at 1200 is so much higher than my idle I really couldn't even smooth it. I'd just have to basically copy my HOT to my idle which as you say defeats the purpose of an idle table.
3. The car seems to idle better at 17 degrees than it would if in the HOT table of ~31 deg.
4. The stock idle and HOT tables are quite far separated if you compare them and a stock LS1 transitions just fine. I've not had any real issues w/ off idle transitions in parking lots, etc. I don't have the bucking either, but perhaps a larger cam would benefit more from this type of tuning.
Dave
Thanks in advance guys
Dave
