base tune for lq9 with mild cam and headers
Old Sep 15, 2017 | 05:08 PM
ecoman35's Avatar
Default base tune for lq9 with mild cam and headers
just finished swapping a lq9 into my 72 chevelle. trying to tune with hp tuners but i am new to this. does anyone have a decent base tune that i could download to start with. 2003 lq9 from escalade long tube headers auto with 2800 stahl and 4:10 gears. cam specs 222/226 586/569-114+2. dbc thanks for any help
Old Sep 15, 2017 | 05:28 PM
01ssreda4's Avatar
Add 20% to the VE table and get going. It'll be close enough to be safe and get you started.
Old Sep 15, 2017 | 05:31 PM
gagliano7's Avatar
If you go to the Hptuner's repository you could probably find something close to look at and see the diffences.
Old Sep 15, 2017 | 05:36 PM
01ssreda4's Avatar
cam is probably gonna want a little less fuel at idle, so plan on it being a little rich, and probably a little more at WOT upper rpms, so plan on adding some. So 20 is a good round number between the two.
Old Sep 15, 2017 | 08:43 PM
Haggar's Avatar
Take a look at this post:
https://www.hptuners.com/forum/showt...de-(w-pictures)
Most of the pics don't work anymore, due to changes to photobucket, but the info is good. I'm starting to tune my LQ4 swapped into a 1971 GMC Jimmy. I've running headers, CNC'd heads, 4" Intake, 3200 Yank, 223/231 .63x/.61x cam, Corvette LS2 Injectors, 4L65e. I've been using the info in that first thread, and have the truck idling pretty well now, and drives pretty well. I need to get my wideband wired in and start on part throttle next.
Old Sep 16, 2017 | 07:18 AM
ecoman35's Avatar
The pcm is a 411 from psi that i got my harness from. the guy doing the tuning told me it identifies as a v6. is this going to be a issue?
Old Sep 16, 2017 | 10:24 AM
2xLS1's Avatar
Find a new tuner.
Old Sep 18, 2017 | 08:35 AM
01ssreda4's Avatar
That setting in the computer has no effect.
