Weird car is weird.
My torque pro says the car is idling at 850rpm, but it's at 1200 tach shows 1200 as well.
no throttle response
rev down takes about....forever
no power until 4K and even then it's meh at best.
Both the cam position sensor codes , high voltage and low voltage
So far I have put in a new cam sensor.
And re-wired the cam sensor.
in starting to think the car has not been tuned for the ls2. But even the factory tune would know what RPM the engine is at. I'm just chasing my tail at this point.
Any ideas? Thanks fellas.
some new questions.
Is there a benefit to running a ls2 style cam sensor? I am trying to understand why he would do the ls2 cam sensor.
How do I know if the car should be using the ls2 cam sensor or the one at the back of the block?
I am going to plug in the rear sensor and see if the code goes away.
If the cam sensor only serves to start the car then I can safely assume that my other issues(throttle response low end power ect.) are being caused by the tune and not the cam sensor?
If so then I can have the car tuned even with the code present?
As long as the PCM receives the Crankshaft Position sensor 24X signal, the engine will start. The PCM can determine top dead center for all cylinders by using the Crankshaft Position sensor 24X signal alone. The PCM uses the Camshaft Position sensor 1X signal in order to determine if the cylinder at top dead center is on the firing stroke, or on the exhaust stroke. The system attempts synchronization, and looks for an increase in the engine speed indicating the engine started. If the PCM does not detect an increase in the engine speed, the PCM assumes an incorrect synchronization to the exhaust stroke, and re-syncs to the opposite cam position. A slightly longer cranking time may be a symptom of this condition.
I believe you it will start. But guessing the sequential aspect? I think thats a myth.
im not saying its impossible I just never encountered this. Mega squirt for example wouldn't do this, I never read anything like this. I would have remembered.
hooked up the rear cam sensor and boom shes running great and fires right up. No idea why that timing cover was on a gen III iron block. but whatever.
Now I just need to figure out the injector size and engine displacement so I can get it tuned. This whole 1200RPM idle crap is getting old.
if you read what 2xLS1 said above, the PCM measures the crank's acceleration on each ignition event, and from this it can easily determine which stroke/phase each cylinder is on (it's not guessing, it's measuring crank acceleration or lack thereof);
the 24x CKP reluctor is encoded, this allows the PCM to know which cylinder pairs are approaching TDC, it needs this signal to run the engine;
the PCM uses the CMP signal to sanity check the phase, if it disagrees, a CMP DTC is thrown
(i.e. ignition events correlated to CKP have more relevance/priority over CMP);
it does not need to use injector batch mode and/or ignition waste spark;
the reason that batch mode and waste spark were used the 1980's is because their CPU's were not fast enough to keep up at higher RPM's.
