SES light does not work - tuned out?
Old Oct 14, 2017 | 07:28 AM
TheNutDriver's Avatar
Default SES light does not work - tuned out?
I posted this in the electronics section some months back but didn't get a reply, so figured id try in here with all you tuner guys!
The SES light on my 01 WS6 doesn't work at all. Even when i turn the ignition on, it doesn't light up. Im guessing that at some point during the cars tuning life, somebody has disabled the light completely. Is this a possibility?
If not, what else could cause this as i am lead to believe there are no bulbs for these dash lights, its an LED on the PCB?
Cheers
James.
Old Oct 14, 2017 | 11:23 AM
2xLS1's Avatar
You need to take the cluster out and take it apart and test the bulb or led.
Old Oct 14, 2017 | 11:26 AM
So there IS a bulb then? I was under the impression it was hard wired into the PCB of the cluster.
Ok I'll get it checked out. I'm guessing the guy I brought it from may have took the bulb out then to hide the light for the bad TPS it had when I got it.
Old Oct 14, 2017 | 02:33 PM
2xLS1's Avatar
Bulbs can also be soldered on to the PCB in the cluster just like a LED.
