Map sensor
Old Oct 24, 2017 | 07:54 PM
Heavy1Mcgee's Avatar
Default Map sensor
I did a Ls Swap on a 85 Monte Carlo SS , it's a 6.0 with Ls3 intake and heads I have a 04 Chevy avalanche computer we started out using the Ls3 map I was told by tuner that the map reading wasn't high enuff so I Switch back to the original Map sensor thinking maybe the computer wasn't recognizing the map from the LS3,still no good can not get map to read 100 I'm stomped
Old Oct 24, 2017 | 08:04 PM
The 04 computer is for a Gen III engine. All sensors must be Gen III. Does the Gen III MAP sensor fit the same way as the LS3 MAP sensor?
