E38 standalone p0315 ckp case relearn
Old Oct 27, 2017 | 07:49 AM
gjarami's Avatar
Default E38 standalone p0315 ckp case relearn
I have LY5 engine with E38 in my cj7 with old manual trans, it don't have BCM and TCM, I have one code, p0315 with 4000rpm issue and I need ckp or case relearn procedure, I connect trans park/neutral to ground, and brake signal to 12v applied and 1k resistor to ground released, tech II can't began the relearn procedure, in tech II engine info shows park neutral applied and bpp ( brake position pedal) invalid, how can I fix the brake signal? and how can I finish the standalone ckp relearn?
Old May 4, 2024 | 06:57 AM
atlasman's Avatar
Did you ever figure out the E38 ecm, BPP issue? What was the solution?
Old May 4, 2024 | 09:45 AM
Uhh... SEVEN years later?? REALLY??
