Tuning problem or somethin else?
Old Nov 10, 2017 | 09:56 PM
rossp's Avatar
Default Tuning problem or somethin else?
I recently bought a trans am that already had h/c/I. Ever since I've had the car it will not start and run without throttle. It has a pretty bad surge until it gets up to temp even with throttle applies at around 5% or so. Even at operating temp you have to apply throttle for it to fire and stay running until everything settles down. Since I've started fooling with the tune I've swapped to a 1 bar sd operating system with hptuners and an 02 stock tune. I copied everything over to this tune from the previous tune the car had in it when I got it. I talked to the owner that actually built the car and had it tuned. He said the car ran perfect when he sold the car to the guy I bought it from. This leads me to think I have a problem other than the tune. Does anyone have any idea where I should start with this problem?
Old Nov 11, 2017 | 08:42 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
A bad IAC could easily cause the exact problems you describe.
Old Nov 11, 2017 | 11:32 PM
rossp's Avatar
I adjusted on the idle screw and reset the tps. All
Is good now.
