Software transferable?
Old Nov 13, 2017 | 02:05 PM
nightriderc5's Avatar
Default Software transferable?
I bought a CTS V that has a cam, heads, ect. and was tuned with a different software than what i have. My question is, can I pull the current tune onto my HP Tuners software without having issues? I have a check engine light for rear O2s which have been deleted, also wouldn't mind seeing what they have going on with the current tune.
Old Nov 13, 2017 | 02:15 PM
01ssreda4's Avatar
As long as you pull it directly from the PCM/car it will read fine.
Old Nov 13, 2017 | 04:21 PM
will i be able to change or write a tune back in okay to i assume?
Old Nov 13, 2017 | 07:20 PM
JoeNova's Avatar
Restricted User
You'll be able to change almost everything. You might run into some hangups changing the OS because HPT and EFILive both use custom OS.
Old Nov 17, 2017 | 10:29 PM
rpturbo's Avatar
At worst case after you read the tune, you'll have to re-flash the pcm with a clean slate or different OS and then you will have everything to set the tune back up, but it will cost more credits.
