Holley EFI on 98 Trans Am
Old Jun 5, 2017 | 02:45 PM
84c10's Avatar
Default Holley EFI on 98 Trans Am
Anyone have tips on installing aftermarket EFI on a 98 Trans Am? what all do I need to tie into? Id like the factory gauges to work, ABS, etc. I'm guessing I can tie into the OEM with an RPM signal for tach, add temp sensor to the right rear head for coolant temp, Fuel gauge will still work. Will the ABS still work or does it need something? what about speedo? can you tap into the VSS? I read the 98 was still analog gauges so I think that will be easier. thanks for any help
Old Jun 11, 2017 | 07:12 AM
Eldogg's Avatar
I've got a few questions.
A4 or 6spd?
I haven't researched the 98 PCM yet but I'm working on a Piggy Back Plug & Play Holley harness for GM applications. Let me know if I can help.
Old Nov 16, 2017 | 11:52 AM
1BADWS6@STENOD's Avatar
A4 or 6spd?
Have you finished this plug and play harness? Very interested in this! What applications are you working on?
Old Nov 17, 2017 | 11:05 AM
Sube's Avatar
This is a good thread from a couple of years ago that I saved that specifically talks about 1998 f-bodies https://ls1tech.com/forums/pcm-diagn...dominator.html
Old Nov 17, 2017 | 11:45 AM
neblackshirts's Avatar
A4 or 6spd?
A piggy back system w/Holley EFI would open a lot doors in the 98+ f-bodys. I've seen MS3pro systems piggy backed on 98+ f-bodys. A local shop here in Lincoln, NE "The Shop, Inc." has done it with Sketchy Vert an 02 I believe 1000+hp T/A.
Your with Detroit Speed, that DSE-Z is an absolute animal love it!! That build has really made me second guess my 01 Z as I've always had a soft spot for nice 3rd gens, killer build you guys!!
Old Nov 17, 2017 | 12:25 PM
LSX Power Tuning's Avatar
We prefer for a much cleaner install stall and remove the 20 year old wiring and inaccurate cluster and use the Holley touch screen. While its not for everyone a stock cluster is in a 98 is very inaccurate, I wouldnt trust any of the readings off the stock cluster on a performance build.
Old Nov 18, 2017 | 08:42 AM
LilJayV10's Avatar
You need to split the crank and cam signals so both the stock ECU and the Holley see them.
The more challenging part is figuring out what size resistor you need for the crank signal to make both ECU's happy.
You will need an oscilloscope and an adjustable pot to figure out the resistance you need.
