Can i add a analog signal to retard the timing on E67
I want to add a tract control to my LSA i need to add a analog voltage input wire to retard the timing when it spins. It will also tell it long much to retard. I know there are timing tables in the comp that could do this. How do i find one and add the correct wire so i can program the timing curve?
Any Help would be greatly appreciated
thanks Brian
thanks Brian
thanks Brian
thanks Brian
Theres a traction control you can buy that works with any system capable of retarding the timing via a analog signal. Ive seen it on a car and it works but no one knows what wire i need on the E67
Sounds like the LS ECM does NOT handle analog signals for timing adjustments.
