DBW pedal stuck(?) at 1500 rpm
Old 11-25-2017, 07:22 AM
chuckd71's Avatar
Default DBW pedal stuck(?) at 1500 rpm
I'm going to call Speartech about this later, but thought I'd solicit ideas here as well while waiting for them to open.
Short version is this: L92/T56, Speartech harness, DBW Corvette pedal/tac/etc. Came home for holiday, drove car around, on the way home the car suddenly stuck at 1,500-2,000. Fortunately it would slowly creep back up to this rpm after I shifted so I could still limp home. Pedal was not physically stuck on anything. Disconnected all power, still did it. Got home and stopped car for a minute, decided to go move it around in the garage and it was fine.
Any thoughts on what might cause something like this from a computer perspective? It might be ok now but if this happened on the road if I were taking it to NC or something I'd be screwed.
Thanks for any insight
Old 11-25-2017, 10:02 AM
brandon6.0's Avatar
Try cleaning throttle body. Also make sure tb and pedal are plugged in good.
Old 11-25-2017, 03:39 PM
chuckd71's Avatar
Good thoughts. I'll do that now while it's still sunny
Old 12-03-2017, 10:48 AM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
L92 does not use a TAC...
Andrew
Old 12-09-2017, 07:51 AM
chuckd71's Avatar
Something tells me this one does. I'm wondering if maybe the TB itself just got stuck.
Old 12-09-2017, 10:45 AM
That is definitely a gen 3 ECU. Not sure why Speartech would use that on a L92...
Andrew
Old 12-09-2017, 06:16 PM
Old Geezer's Avatar
Sounds like limp mode....
Quick Reply: DBW pedal stuck(?) at 1500 rpm
