OMG I almost busted a nut
Old Jul 1, 2004 | 09:35 PM
HumpinSS's Avatar
Default OMG I almost busted a nut
when HPTuners reflashed my PCM in 27 ******* seconds. Man does that up the ante from the devil (Edit)
Old Jul 1, 2004 | 10:19 PM
jimmyblue's Avatar
Moderator
Not only that but I've reflashed my PCM over 20
times without one hang, never have used the built-
in recovery feature. Decent comms - nice to have,
go figure.
Old Jul 1, 2004 | 11:30 PM
HumpinSS's Avatar
Have you been succesfull in smoothing out your ve tables using the 3d graph. Man does that thing with the mouse have a serious learning curve
Old Jul 2, 2004 | 04:59 PM
Another_User's Avatar
go figure.
20 times...I think I have done it at least once a day since I got the thing...and that was a month ago or more. Not a single problem.
Old Jul 2, 2004 | 05:13 PM
slow's Avatar
mine takes 0:36 with a bare bones, under powered laptop, P150 32mb
very impressed.
used the recovery feature once, on a messed up PCM, HP tuners has never caused a problem for me with my own car's pcm, 100% satisfied
Old Jul 2, 2004 | 07:16 PM
HumpinSS's Avatar
sshit i have flashed at least 5 times since i got it yesterday
Old Jul 3, 2004 | 12:55 AM
Ha ha ha. Sweet. HPTuners rocks. Now if only they would update a few things for me...
Old Jul 3, 2004 | 01:13 AM
pow's Avatar
pow
Whats need to be updated with it?
Old Jul 3, 2004 | 08:26 AM
ace68's Avatar
how much differance is there between edit and tuners? I flash mine with edit and it only takes 1min., 23 second differance ain't a big deal. also edit will be logging data shortly. But I don't mind changing over to efIlive it's easy.
Old Jul 3, 2004 | 09:52 AM
I want to be able to adjust the noise floor, or whatever it is called, on the knock sensors. I posted on HPTuners board...I hope they decide to do it.
Old Jul 3, 2004 | 11:50 PM
Bink's Avatar
WOW!!!!!!!!!!!!!
How is that monster you built?? My car is still down.
Happy Fourth HumpinSS!!
joel
Old Jul 4, 2004 | 11:08 AM
HumpinSS's Avatar
I am getting it togther. Working out som PT issues STILL. WOT seems to be fine a little fat but fine. Just driveability is killing me
Old Jul 4, 2004 | 05:20 PM
Bink's Avatar
Why driveability??
Old Jul 4, 2004 | 06:11 PM
samz28's Avatar
hptuners rock, now edit just needs scanner, and unlocked vin and a new interface and hell that'll never happen in this lifetime
lol
Old Jul 4, 2004 | 06:28 PM
HumpinSS's Avatar
Originally Posted by Bink
Why driveability??
Stupid little quirks like the car hunting for an idle when the ac is turned on or stupid little kr retard at the stupidest most confusing times or a little surging when in gear cruising at 1500 rpm. Hopefully when i scale the ifr table that will help with it. I am still messing with the idle (4,8,12 hundred) rpm ve values to help cure it. Its just a long process, the good thing is I dont have to go grey waiting for edit to flash the pcm
Old Jul 4, 2004 | 08:44 PM
Bink's Avatar
Do you have a wideband O2???????????
Old Jul 4, 2004 | 11:15 PM
HumpinSS's Avatar
Nope and I wish to hell i did. This way i can run the **** in OL and call it a day. I think 14.7is to lean for ANY cam
Old Jul 4, 2004 | 11:20 PM
HumpinSS's Avatar
Instead of buyin the roller rockers that i have been longing for looks like inovative may get some business
