Cooling fan - LTFT oddity
The fans seem to work as advertised, but are pulsing on/off at a high rate and seem to run at about 50-70% normal speed. When I activate FAN1 in the Scanner, the fans speed up to full speed...not entirely abnormal(?). However, when I clear my Long Term Fuel Trim, I get the same effect for a period of time. After several minutes of LTFT relearn, they return to the pulsing/lower speed.
Any ideas on what causes this?
Activating Fan Relay #1, #2, & #3 should run both fans at full speed, This runs the fans in parallel.
Do you have it wired exactly like a '99-'02 F-Body?
Assuming it's wired correctly.....
Go into the tune & make sure that "recirculation fitted" is set to Fan #2 as a 2001 truck PCM will be set to A/C Recirculate which is incorrect for what your doing.
