LTFTs low at idle, high while cruising
Old Dec 24, 2017 | 04:42 AM
ilya_k's Avatar
Default LTFTs low at idle, high while cruising
Hi all,
I have a 2004 5.3 engine swapped into a wrangler. Engine is stock. Intake is basically open element filter to 4" pipe to a 90-degree
elbow. Exhaust is LS3 manifolds to 2.5" pipe to Y-pipe to 3" pipe and muffler (no cats). The tune is stock aside from small stuff
like fans, VATS, DFCO etc.
Idles and drives fine, but LTFTs are about -10 at idle and +10 while cruising at 2400 rpm. Up to +18 on heavy acceleration.
LTFTs are almost the same on bank 1 and bank 2 (+-2%), so it doesn't look like an exhaust leak. Cleaned MAF, no effect.
Got the injectors cleaned and checked, they are good as new. O2 sensors are new ACDelco 213-1702. Fuel pressure is 59-60 psi.
Does that look like a symptom of some common issue? Can it be because I'm running non-stock intake and exhaust?
Old Dec 24, 2017 | 06:21 PM
baronsmith98's Avatar
Can you post a log file? Are you running the factory MAF?
Old Dec 25, 2017 | 08:02 AM
01ssreda4's Avatar
Im not sure what youre asking. These cars arent like 0 trim stock. Trimming like that is normal on an untuned vehicle. IF its tuned (and its similar weather to when it was tuned) then i would say someone doesnt know what theyre doing. But for a stock car the tunes are basically garbage, getting worse as soon as you modify anything.
Old Dec 26, 2017 | 02:58 AM
ilya_k's Avatar
I'm running an OEM MAF, but it is not from the same donor as the engine. The engine is from a 2004 suburban and my MAF is from a 2003 tahoe.
Here's a log I recorded a couple of weeks ago (highway cruising around 7:15).
File Type: hpl
Old Dec 26, 2017 | 03:11 AM
ilya_k's Avatar
I'm trying to understand whether it is a problem with something mechanical/electrical or with the stock tune. Fixing the tune when the problem is somewhere else doesn't sound like a good idea. I have no experience and I don't know what the trims on a vehicle with non-stock intake and exhaust can look like.
Old Dec 26, 2017 | 07:43 AM
01ssreda4's Avatar
They can get wacky. Also, wideband readings tend to be way off what you are expecting also.
Ok so looking at the log, it seems pretty normal except a few things. At one point it is commanding 16.0 AFR, which i dont like. Fuel trimming looks decent then there are areas where it does act kinda wacky for short periods but they seem to be near areas of throttle transitions and stuff....but yeah the fact that it spikes into the 20s doesnt seem completely normal, though disregard if its after a throttle lift and the o2s are pinging lean.
Old Dec 27, 2017 | 09:01 AM
ilya_k's Avatar
Thanks, I missed that in the logs. I did some more logging and it seems that sometimes commanded AFR changes to 16.0 for about 25 seconds and then changes to 13.6 for another 25 seconds. From what I've been able to find it is the cat test that can't be disabled in P59 PCM.
Old Dec 27, 2017 | 09:44 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Factory tunes are allowed plus or minus 25% correction, and many take almost full advantage of that. Once you modify even the smallest item from exact factory configuration, all bets are off.
Old Dec 28, 2017 | 08:21 AM
01ssreda4's Avatar
Yeah on our dinosaur 411 pcm we can disable that cat bs. Course I don't log as much as I should so who really knows.
Old Jan 4, 2018 | 04:42 AM
gagliano7's Avatar
Was the commanded 16.0 while you were out of the throttle? Could be DFCO.
Looking at your log all your part throttle ST trims look fine except for a couple areas in the higher rpms. I couldn't see wideband on my scanner. You could straighten that out with a tune no problem.
Old Jan 4, 2018 | 01:47 PM
ilya_k's Avatar
Thanks. I don't have a wideband. I will try tuning by ltft/stft as soon as it gets warm enough. And the 16.0 commanded AFR was not caused by DFCO, here's another log (the cat test starts at 3:30:07, ends at 3:30:59).
File Type: hpl
