Uneven fuel trim readings between banks. Why?
My bank 2 ltft and stft #s look crazy- they go as low as -20 at idle and part throttle, but are closer to zero at wot. My bank one numbers look good- stay between -4 and 0. The two banks should not vary that much at idle and part throttle.
Recently, I cleaned my sensors and had the valve covers off due to a valve springs, seals, pushrods and cam swap. I checked the egr gaskets and they are not leaking.
I added +3.5 PE after the cam swap because I looked lean at wot and I would rather be safe than sorry while I wait for my pcm dyno tune.
What could cause this situation?
[QUOTE=P Mack]How did you clean your sensors?
scrubbed carbon/soot off with a rag soaked in parts cleaner. light sand with 1200 grit sandpaper.
Did your problem start then?
I had a rocker arm bolt break on ex. cyl. # 1. After I fixed that I took off all the rocker arm bolts and reinstalled them all to spec. I cleaned the o2 sensors at this time as well.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I used a propane torch to clean my o2 sensors. It worked great and they have been functioning as well as before for over 2k miles. I am changing them out for Denso O2s when I get off my lazy butt.
[QUOTE=Cheatin' Chad]I used a propane torch to clean my o2 sensors. It worked great and they have been functioning as well as before for over 2k miles.
I will try that.
I will try that.
