E40 compatibility with LS1 DBW Throttle Body
Old Jan 24, 2018 | 09:33 AM
CrazyPa's Avatar
Default E40 compatibility with LS1 DBW Throttle Body
Has anybody ever successfully operated an LS1 Throttle Body using a 2005 E40 PCM and Corvette Throttle Pedal?
I realize this would require a modified or custom harness.
I have a low mileage LS1 engine out of a 2001 Corvette and I am installing it in an 89 Corvette. I want to avoid using the C5 TAC and Pedal. I also have a 2006 4L65e GTO trans with the T42 controller that I can use with the E40 setup.
I find a lot of info about running an LS2 throttle body on an LS1 on a 411 ECM, but nothing about going the other way.
Thanks,
Gary
