Weird problem after changing injector data from sticky above
6.0 DBW
PO1 0411 pcm
3 bar OS
Siemens Deka 80's
Walbro 450
LJMS stage 2 turbo cam
S480 turbo
4L80E
Tuning in OLSD with wideband
I'm using the truck fuel rails with vac referenced regulator
I got the thing running a while back using Matt Happel's 2500 Silverado tune. I've been tweaking on it since. I was addressing a lean tip in and finally convinced myself that the VE table numbers were just too high compared to others that were similar. So I used the injector data from the sticky above. Sure enough, I can lower my VE table to more comparable numbers now. BUT, the idle is screwy. In park/neutral it's rich (~13.0 AFR). In gear it's almost perfect (~14.8 AFR). I can lean the idle out in the VE table when it's in park or neutral, but then it becomes too lean in gear. The MAP goes from around 60kpa in park and goes to around 70kpa in gear.
I changed:
Min Fuel Milligrams in transient
Flow Rate vs. KPA
Offset vs. Volts vs. VAC
Short Pulse Limit
Short Pulse Adder
Min Injector Pulse
Default Injector Pulse
Any idea what I did, or need to do to correct this?
Like I said, I'm pretty new to Hp tuners, so any and all help is much appreciated.
https://drive.google.com/open?id=1Yr...yrJanMyyov_CL2
Oh yeah, thanks for helping. MUCH appreciated!
Are you running a returnless or return style fuel system? The flow rate vs KPA tables show different trends in your tune. If you are using a returnless fuel system then you need to have the flow rate gradually rise with increasing KPA. If you are running a return style system then the flow rate can stay the same across all KPA levels.
I'm going to look into the VE table changes that you found for me. Thanks again for helping!
