Inexpensive Opensource Flashing(Read is 100% working)
It's not US built but it's a quality product. Might be from Canada.....don't recall off hand but it wasn't China.
The above device is what I have written a "Guide" for if you will on how to install and use it. Any other brand/type your on your own.
Just keep in mind this requires opening the pcm up and soldering onto the pcb. It's not done over the data port.
Awesome thanx, i have just ordered two of them, I like to have spares.
If you ever need any testing, let me know
I have over heaps of pcms here Ls1, E38, E40, BA-FG Pcms
I have open licenced HP Tuners
Many scan tools
And heaps of other gear as well..
Always happy to help..
https://drive.google.com/open?id=19d...tO6w4lnQ8S9ViL
what if you used this idea to connect a usb cord through the pins in the ecu that are listed as unused, and then just ran the usb cord into the cabin of the vehicle?
The next issue you MIGHT run into is interference from being in such close proximity to the other signal wires from the engine.
USB cables have a specified maximum length, once you exceed that all bet's are off. In most cases a quality cable can be several feet longer with out an issue but results may vary from one cord to the next.
But in theory what your saying would work...although drilling a hole in the pcm's case isn't the issue it's keeping the USB cable end clean and dry.
For those that have't read the instructions document, when using the BDM there is 1 wire that needs to be switched "On", it puts power to the flash chip that allows writing to it. You can read the Pcm with out this wire but it MUST be turned on to write. One of the aspects of using the PIE ZERO to do this was that you could use one of the Pie's I/O pins to handle the switching automatically. Doing it as suggested above also would require a switch be placed in the same area as the USB cable's end so you can enable write. If you leave the switch "On"....nothing bad will happen but it car won't start. You have to turn the switch"Off" and turn the ignition switch off to return the PCM to a "Normal" state. It's still totally doable but slightly inconvenient.
If someone was knowledge with Linux or specifically the Raspberry Pie and was able to write a simple program to do this I'd be more then happy to work with them to make this a viable option over Wi-Fi/BT...... talk to your friends
I would like to use this type of item to "flash, store, and edit" GM calibrations.
I will also make a "daughter" card for my uses.
There is plenty of I/O (shift light, etc) AND board mounted Broadcom Wi-Fi.
I would like to "share" my progress with LS-1 tech members
Will you, Pete, be willing to "guide" my work ?
I would like to have a product to compete with the GM-Tech-II.
Lance.
Lance.
Then you'd either need to get one of the existing devices working on the Pie like the Allpro or Obdlink or you'd need to create your own J1850 VPW interface and write the firmware for it.
If you were looking for an "easier" way out but it's not a portable solution there is already support for the USB BDM NT on the Pie. Not an amazing option but the flash times are only a couple of seconds VS a couple of minutes if done over the data bus.
Now let me propose an alternative to your Pie interface idea. I already have the program and interface circuit designed to use an Arduino. The program use's 6% of the storage space leaving plenty of room for adding on to the existing code. The Arduino's are also compatible with a great number of displays and can support touch screen interface although it's not going to be as "Nice" looking as the Pie it would be just as functional.
You could also use the Arduino in conjunction with the Pie but change the arduino into a transceiver to communicate with the vehicle. The existing code wouldn't take much to change it over to something more like a pass though device to talk to the vehicle.
If this is something you plan on pursing I'd suggest creating a new topic and sending me the link by PM. I'd be happy to discus this idea in greater depth openly for others to learn from but I don't really think it's an appropriate conversation to continue in this particular thread or it's going to get way off track.
I agree with Pete that we should start another thread for a Raspberry Pi version. I'll help out when I can.
On the Windows from, we are very close to having something that we can release that will read the contents of the PCM.
Thanks
how does one interface with a vehicle that doesnt have a regular obd2 serial port?
I think the OBDII connection has spoiled us to a degree! lol
