Inexpensive Opensource Flashing(Read is 100% working)
Before I try to read it, I thought I would ask if you think this might read it.
What exactly would it take to give 3-bar support to an OS?
* rescale the MAP sensor
* rescale the MAP axis of the open loop fuel table
* rescale the MAP axis of the timing table
* rescale the MAP axis of the VE table
Am I missing anything critical?
I'd also like to know what it would take to convert an OS to speed-density... I've heard people talk about failing the MAF sensor but that I suspect there's more to it.
(I've got plenty of experience tuning and hacking Subaru, but I'm new to GM.)
-There's already a MAP sensor setting in the OS that you can have it scale to a 3 bar or more (can't remember the max value)
-Timing is based off calculated airflow, so there's not really anythign to change there, though i'm sure if that table could be rescaled it would be awesome. HP Tuners does not rescale it so people end up scaling on their own by fudging the engine cylinder volume, VE table, injector size, etc, to keep it on the table if they want, but if it goes off the table it uses the closest cell so you just dial your timing in on that last row.
Open loop is only critical for out of PE mode I think, it'll go off the PE settings if you trip it instead, or whichever is richer or something or other, not really sure there.
So that leaves the VE table, which definitely needs to be able to put in values over 100 kpa. Technically you could do like the timing and dial all your fuel for max boost in there, but that would be terrible.
The other major thing is a special PE table for boost, so once you get into the postiive pressures you can tell it what AFR to shoot for basically.
As far as Speed density, it runs in speed density mode by default if the MAF fails. I'm not really even sure they do anything special for that except force the MAF to fail on the first error detected, because you still have to force it to fail with the custom OSes or it doesnt work right.
I've got a few PCMs and the ability to flash whatever OSes on them that I want, and a flex fuel turbo car if you need a guinea pig. I don't have the time to get up to speed and help with the actual development right now, but I'd be happy to test stuff out.
The first code change I want to do is to change the inputs to the fuel table to load and RPM, so it'll work just like the timing table. No need for PE after that, and no need to create BE to support forced induction.
But, coming from a platform were the fuel table and timing table both have RPM along one side and load across the other side, they both seem like unnecessary complications.
If you want more fuel at X RPM and Y grams, you should be able to just tweak that cell in the fuel table, same as you would for spark advance.
But, for GM.... it looks like if I change the airflow scaling for the timing table, that will also require rescaling a few other tables, and I don't even know what those tables are for yet, so this isn't something I could actually do any time soon.
What other tables do you think you'd need to rescale if you changed just the timing table?
caveat emptor: i'm 100% regurgitating what i've been told ...im no hex programmer
i'm still being a bum on my end btw Pete...just trying to get this damn house sold!
NSFW: can I bug you about alpha-N tuning via PM? I've been tasked with tuning an E30 that's running microsquirt (and using ITB's with a turbo-yikes)
