VSS Signal
Old Feb 18, 2018 | 09:48 PM
bpope's Avatar
Default VSS Signal
Hello,
Looking for a little help for the wiring/electronically challenged. I have a '94 300ZX with an LS1 and T56. The ECU is from a 2000 Camaro/Firebird. I verified the wires from the VSS are wired into the ECU (Red Connector Pinouts 20 and 21). I am trying to get the factory speedometer to work. My question is, with a stock GM car - how does the VSS signal (pinout 50) wire into the factory speedometer. This is one wire from the ECU and I'm trying to figure out how it hooks up from the factory, in hopes of helping me hook it up to the factory Nissan speedo. The factory Nissan speedo receives an electronic signal. Thanks for the help!
Old Feb 26, 2018 | 02:52 PM
bpope's Avatar
Anyone, or am I in the wrong forum? 10 year noob, here. :-)
Old Feb 26, 2018 | 03:30 PM
Give it a little more time. Sometimes it takes a while to get the right person to check in to see the post.
Old Feb 26, 2018 | 10:16 PM
toplessHO's Avatar
normally they work with a PWM signal
you need to find out how many pulses per mile
your Nissan speedo uses and correct the output
of the GM VSS to that value.
PM me on this I may have the converter box you need.
Old Feb 27, 2018 | 08:55 PM
bpope's Avatar
Good point. Thanks!
bpope's Avatar
Thanks, I will do that!!
Old Feb 28, 2018 | 07:53 AM
toplessHO's Avatar
build that sine to square wave converter and dial it in on HP tuners
good luck
Old Feb 28, 2018 | 09:19 PM
bpope's Avatar
good luck
Thanks again for the help!
