Lounch control for LSX
You can choose the amount of Spark Retard UP TO 100* with 60* as common.
You can choose the RPM of when this happens.
You can choose the "trigger" with a common switch on the Clutch Pedal.
You can choose a "stutter" table rotation based on your choice, often by knowing your firing order then drop/fire/drop/drop/fire, etc.
The correct rotation will have the effect of a smoother running engine at start line.
The "rotation" method, my method, is NOT common AND allows for the cylinders to stay hotter.
Lance
