the injectors and coils have seperate voltage feeds and both are getting voltage key on and cranking. thanks for trying though. ok so i now have the upper o2s plugged in the coils plugged in and the coolant temp. So as of now everything to run is plugged in and my small scanner shows Intake temp, coolant temp, map reading, throttle % and RPM signal when cranking (about 120 rpm) still no pulse using a noid light plugged into injector plug. The computer has good grounds, ignition voltage key on and cranking and constant battery voltage where needed. the brake switch is holding voltage to pin 33 on blue connector once brake is pressed voltage goes to 0. the one thing im stuck on is what to do with the park signal on blue connector pin 34 i currantly have nothing on it as my understanding the computer uses the pressure switches in the trans to find the gear selected. is this true or should i have a ground input to this pin? i have only my little scanner today so i cant see anything more then basic data steam information. any thoughts on this park signal?
