Question about 3 Bar Map sensor for ls6 intake
Old Mar 11, 2018 | 07:26 PM
dont z20h8's Avatar
Default Question about 3 Bar Map sensor for ls6 intake
looking To see if there is a 3 bar Map sensor that will directly bolt on to the ls6 intake.
Ive seen a couple threads were people are taping the intake with a fitting and running a piece of hose I’m just not trying to go that route unless I completely have to, I’d rather have plug and play.
any input would be helpful I’ve done a few searches but everything i see is from old threads.
Old Mar 12, 2018 | 01:46 PM
turboffr's Avatar
I found this one and was just getting ready to post here to see if anyone has used it and if it's any good. DSteck isn't making his 2.5 map sensors anymore and I need a sensor.
https://www.efisource.com/wp/shop/ls...ar-map-sensor/
Old Mar 12, 2018 | 02:03 PM
Mavn's Avatar
"I MAID THEESE"
That's the one I run
Old Mar 12, 2018 | 02:41 PM
dont z20h8's Avatar
I’ve seen a lot of threads about that sensor with people have mixed feelings about it but I’m just going to bite the bullet it’s only $34
Old Mar 12, 2018 | 02:57 PM
Fierro51's Avatar
i know several people in my town using the efi source sensor with no issues
Old Mar 13, 2018 | 09:28 AM
01ssreda4's Avatar
ZR1 sensor and drill the hole out to 1/2"
Old Mar 13, 2018 | 11:11 AM
02z28marom6's Avatar
I recently converted to a 3 bar OS. ACDelco 3bar MAP Sensor part number 12615136 is the one I use. Works great and personally would not use anything other than ACDelco for sensors. Had to use a file on the map sensor to fit. Doesn’t effect anything. The good thing about that is you don’t have to mess with your intake. And if you use HP tuners it will update all settings properly for this map sensor.
Old Mar 14, 2018 | 11:42 PM
stillspinnin's Avatar
Default 3 bar map
I have the efi source 3 bar map sensor for the ls6 intake its new. I decided I was going to switch to the other style u dont like I'll charge u 35 shipped to your door
shoot me a pm
Old Mar 14, 2018 | 11:55 PM
dont z20h8's Avatar
shoot me a pm
why did you make the switch? And I’ve already purchased the one from efi source.
Old Mar 14, 2018 | 11:58 PM
dont z20h8's Avatar
I already purchased the one from efi source i did save the part number you recommended that way if this one doesn’t work or I don’t like i will try that one. Thanks
Old Mar 15, 2018 | 03:14 PM
turboffr's Avatar
Isn't that a 2 bar sensor?
Old Mar 15, 2018 | 04:45 PM
JoeNova's Avatar
Restricted User
Yes it is.
Old Mar 16, 2018 | 05:36 AM
turboffr's Avatar
Do they provide the offset values needed for HP Tuners?
Old Mar 16, 2018 | 07:38 AM
01ssreda4's Avatar
Yes they do
