411 ecm narrowband simulation?
https://ls1tech.com/forums/pcm-diagnostics-tuning/419524-heres-how-wire-lc1-work-wideband-narrowband-same-time.html
... But I'm not sure what ecm its For and the link is dead for the wiring
Personally, I've done just fine running a separate WB a few inches behind my bank 1 O2 sensor. Just a little welding required, which is easy peasy, and then you aren't trying to recalibrate a "narrowband" "WB" O2 sensor. That, and you get more data because you are effectively using 3 sensors instead of 2. I can see if my WB sensor is going bad based on my NB voltages, and vise versa. They do go bad btw, and quicker if you run it rich or use additives.
