DBW Throttle position sticking
Old Mar 30, 2018 | 09:22 AM
Suburban98's Avatar
Default DBW Throttle position sticking
Hi everyone I completed a 5.3l swap on my 98 Suburban using a custom wiring harness to fit from what I can tell a 2011 LMG engine and my stock 4l60E trans. I am having an issue with the throttle getting stuck at high rpms if the accel pedal is depressed in neutral. Its not as bad in drive because theres a load on the engine but doesnt return to idle instantly like it should. If I disconnect the MAF sensor I can depress the accel pedal in neutral and the throttle plate returns like it should but is undrivable. Has anyone come accross this or have any ideas?
Old Apr 7, 2018 | 01:26 PM
Project GatTagO's Avatar
I would first make sure that you do not have any vacuum leaks.
Andrew
