TPS for switch on off?
Old Apr 17, 2018 | 09:31 PM
ElQueFør's Avatar
Get ya one Doug! They're cheap!
Just start playing with writing a simple program to blink an LED. You can take it anywhere you want from there.
Old Apr 19, 2018 | 09:34 AM
TrendSetter's Avatar
I just went out to the parking lot and snapped a pic of my controller.
Its an enclosure from digikey filled with Walmart epoxy.
i made it 3 or 4 years ago and have used it on two trucks through a few firmware iterations.
Old Apr 19, 2018 | 11:46 AM
ElQueFør's Avatar
Very nice. Do you have a bread or perf board on the other side or?
Old Apr 19, 2018 | 12:01 PM
JoeNova's Avatar
Restricted User
I need to find decent arduino enclosures that come with harness connectors. I have 4 Nanos in my car right now and the wiring is getting to be a handful. Not to mention if it rains, they're done. Epoxy isn't a bad idea. Especially with them being nanos ($3/each). Worst case, I put connectors on all of my wiring so I can just disconnect the nano and replace it.
Old Apr 19, 2018 | 12:10 PM
ElQueFør's Avatar
Damn Joe,
What all are you controlling with 4 of em?
Old Apr 19, 2018 | 12:22 PM
i design my own pcbs and have them fabbed at oshpark, so its all one integrated deal.
the one i posted a picture of has a bunch of input and output circuits kind of like a mini megasquirt.
it uses the same mcu as an arduino (atmega328p) with the arduino bootloader, so i can flash it with arduino but its not exactly arduino hardware.
Old Apr 19, 2018 | 02:34 PM
NSFW's Avatar
What are you guys using to step down from 12v to an Arduino-friendly voltage? I ask because I have an Arduino in my Subaru that flakes out intermittently and I'm steering to suspect that my power supply (a little 12-to-7.5 converter I found on Amazon) might be passing noise though.
Old Apr 19, 2018 | 03:07 PM
JoeNova's Avatar
Restricted User
Originally Posted by ElQueFør
Damn Joe,
1. Microsquirt piggyback. Does CANBUS with microsquirt to pull sensor data. Then I input oil pressure, water pressure, 2nd wideband. Datalogs them all together onto a text file that can be opened in MegaLogViewer alongside the microsquirt log. Also does fan control, closed loop IAC control (microsquirt doesn't do IAC control, or fan control), water/meth.
2. Paddle shifters. Outputs to a small 1.8" LCD for a gear indicator. Reads speed from front/rear ABS sensors. Boost controller is also wired to it. Now I can do boost by gear, boost by speed, boost by time, and traction control. Input signal from a potentiometer so I can also do Boost by G.
3. Ignition controller. In order for the car to start, you have to flip a toggle switch to power the ignition arduino. Then a finerprint scanner acts as the ignition switch. It turns on the ignition relay, same as turning the Key to ON. From there all of the arduinos, microsquirt, etc get power. Push button start after that. If the car dies, the ignition relay is still on, so just push to start. Flipping the toggle switch shuts off power to the arduino, and therefor the whole car.
4. Test arduino for the active aero. Still working on this one.
I either run a 5-dollar ebay 12-to-5 volt converter, or use a cell phone charger. I take it apart, fuse it straight to 12v somewhere, and plug it into the USB on the arduino.
If you design PCBs, I have a file I need made. I don't have the time to sit down and figure out Eagle CAD. It always wants a schematic to create a board with, and I just need a prototyping board/breakout board with no components. I can't take PMs on here, but if you're interested I'll give you my phone/facebook/email.
Old Apr 19, 2018 | 08:42 PM
eaglecad is tricky, very unlike any other cad program as far as usability and keyboard shortcuts.
you have to draw up the schematic from scratch into it, ive never imported an existing one.
ill pm with my email
i cant pm you, i guess you have it disabled? let me know your email
Old Apr 19, 2018 | 08:43 PM
thats pretty advanced stuff. i started working on a boost controller a couple years ago but it never went very far. a million projects, we all know how that goes.
Old Apr 19, 2018 | 08:59 PM
JoeNova's Avatar
Restricted User
I'm in LS1tech prison. Can't do anything but post. Can't do PMs, view attachments (including images), edit posts, etc. I've pleaded for them to cut me some slack after like 18 months and was blatantly ignored.
joefields1987@gmail.com
Old Apr 19, 2018 | 09:06 PM
  #32
Joe, I too wish the mods would lift the restriction from your account! You do a LOT more good than harm around here, and are VERY helpful every time I see your posts. For them to persist in this bullshit makes them bigger offenders than you ever were! You have paid your dues a few times over. MODS????
Old Apr 20, 2018 | 12:28 AM
  #33
NSFW's Avatar
https://ls1tech.com/forums/user-supp...e-joenova.html
Old Apr 20, 2018 | 02:27 AM
  #34
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Perhaps you might feel differently if you were paying sponsorship fees to advertise here.
Regardless, the matter is not up for debate and posts/threads such as this and the one linked above certainly aren't helping. To all, including and especially JoeNova, please do not derail any more tech threads with this.
-Admin.
