HPTuners channel config questions
I recently had something weird happen where the channel config I had been using for a while was replaced or something?
Anyways, I can load previous logs and the scanner automatically loads that channel config so I see all the data. The log I made tonight, it won't let me switch channel configs.
So I guess my question is: You have to make sure your channel config is correct before logging or what?
When viewing a log it will always show it in the original config which was used during that log.
So if you add channels and make new logs and then decide to view an old log, then it will show the old log in the old channel config.
You have to manually change the channels around so it shouldn't change by itself.
