Cam harder?
Old May 1, 2018 | 07:02 PM
black&blu's Avatar
Default Cam harder?
I have my idle absolutely dialed in. The problem is now it sounds stock again. This is a texas speed 228R so it had quite the lope to it. I had to play with the cam overrun / under-run and PID's to get it correct. Maybe I can pull some timing? I am running between 16 and 19 degrees at idle.
Old May 1, 2018 | 08:10 PM
brandon6.0's Avatar
If idle is stable and timing is stable thin is dialed in perfectly. To make it choppier just play with the over/under timing tables.
For starters try doubling the stock settings. If it seems to be goin the way u like, just keep adding more to it till u like it.
Old May 3, 2018 | 01:23 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Getting your idle dialed in that good makes you a tuner. Wanting it to sound like crap makes you a poser. One of these attributes is much better than the other. If you really want the big cam sound, just go with a big cam. The real question is what your powerband looks like.
Old May 3, 2018 | 07:46 AM
black&blu's Avatar
It's a Texas Speed 228R cam so it did have a decent lope before it was tamed down. I ended up bumping the idle to 825 and pulling some timing and it sounds really good again. I wanted the idle about 650 but then I have to add a ton of timing, and mess with the PID's a good bit to keep it stable so it loses all the sound.
