Idle Airflow config ?
Old May 8, 2018 | 01:11 PM
Kfxguy's Avatar
Ahhh dang it. I don’t have my computer with me. There’s a table in fuel, then closed loop at the top left. If adds or subtracts fuel vs temp and map. Or it could be your idle air in that temp range. Or like I originally thought, your ve table. My money is on the ve table to be honest. Change it and see.
Old May 8, 2018 | 04:32 PM
JakeFusion's Avatar
Super Hulk Smash
I have a **** ton of air in the colder regions. Over 20g/sec in idle air.
Also, the fueling -- are you taking about the EQ ratio? You probably need to be around 1.10 to 1.15 there in the colder regions at around your typical MAP pressure.
Startup VE doesn't do much. Period. But on startup, I keep the VE table at 100-105kPa @ 0 RPM pretty high. In the 80s, even if everything else isn't. That gives fuel. And if your problem is not airflow related, but fuel related, that's one way to do it. I do that because I'm SD.
Also, if you're running SD, try adding airflow to your MAF so that if it reads the MAF before failure, you have enough airflow in there. Try 15g/sec @ 1500 as that's what it will see before failing over.
Old May 8, 2018 | 04:38 PM
Darth_V8r's Avatar
Moderator
I can't open the file. it says that I am not part of the remote tuning network. GRRRRR.....
I was wanting to look at the Idle - Airflow - General stuff. The IAC reset position, Desired IAC max, Desired airflow max. IAC Park position airflow table also.
Old May 8, 2018 | 04:45 PM
Kfxguy's Avatar
good catch on the maf. What if you just unplug it?
Ive had different results with changing my ve. I’ve had it to where it’ll crank right up or it’ll stumble for a bit and then smooth out with changing nothing but the ve table.
Old May 8, 2018 | 05:39 PM
Monte4ever's Avatar
IIRC I have over 7 lbs/min (52g/sec) in the -40 box and I am running a SD tune (no MAF sensor). The MAF does have something in the first box but I'm at work so can't check ATM. To me my car runs great except for this initial startup issue. I'm really not looking for perfection but don't want to be irritated every time I fire it up while cold. Ima try adding to the follower decay as mentioned further up to see how that plays out. Btw, I thi k my EQ table does have values it the 1.10 - 1.19 range in the problem regions. Also, my 'VE table had a lot more fuel than it does now in the 100-105 kpa areas and ran worse.
Edit: Just remembered that I already have my follower delay in the 25 to 35 range.
Old May 8, 2018 | 05:52 PM
Monte4ever's Avatar
IIRC all those are still stock from a 2002 Camaro.
Old May 8, 2018 | 06:01 PM
Darth_V8r's Avatar
Moderator
Ok I will check those stock values. The first cell in the maf curve thing is necessary any time you write a tune -- if you are SD. If you unplug the maf you still need that first cell like JF described. ESPECIALLY if you unplug maf. Needs fuel until it fails. Even on a SD custom OS.
Old May 8, 2018 | 06:09 PM
Darth_V8r's Avatar
Moderator
OK, try the following (UNITS IN G/SEC):
Desired IAC Max Area -- Set to 120.
Desired airflow Max - set to 50
IAC Park Position Airflow table:
42...39...34...30....21....21.....21.....21....21. ....21
If it does what I expect, it'll start and flare really bad vs stumbling to life
Old May 8, 2018 | 07:03 PM
Monte4ever's Avatar
I'll check the MAF table and change to the above IAC #s tomorrow (at work now) and see what she does. I really appreciate all the help.
Old May 8, 2018 | 08:20 PM
Monte4ever's Avatar
Jakefusion ima add that 15g/sec to see what happens. I'm really leaning toward an airflow problem but what do I know lol. As you guys can see I'm willing to try anything to solve this problem because im lost.
Old May 8, 2018 | 08:41 PM
Kfxguy's Avatar
Let’s do this: (what I did the other day I was having issues)
1) make sure your ve is correct. I keep saying this because ITS VERY VERY IMPORTANT! I chased my tail with idle issues for a while because of my ve was not good enough.
2) put all your idle stuff back to stock. Throttle cracker, throttle follower etc
3) put your stock idle in park and neutral timing tables back in. Add 2-3 degrees of timing to the whole table.
4) put your stock timing in the 400-1200 cells in your main tables. Blend in at the bottom under higher loads.
Flash it.
Start the car. Start your scanner. Force your iac valve shut. If the car does, crack the throttle blade more. Dona tps reset and make sure you unplug your cable while resetting. Start the car again and repeat the process until you can just get the car to idle with the iac closed. Then turn it back on.
5) now run your idle config and do your airflow. If you do your airflow then change your throttle opening, your airfliw will now be off again. Someone told me that it won’t be, but mine always is. So I go by my experience. After these steps, your car should crank and idle well. You may need to play with your spark correction to smooth it out a little more.
Old May 8, 2018 | 09:32 PM
  #32
Darth_V8r's Avatar
Moderator
Maybe I am confused. I been approaching this as if the idle stuff is fine, just seems to cold start poorly, then catch and run fine. So I was thinking the max idle area was restricting the IAC from opening past a certain point, but then adaptive idle kicks in and it takes off and runs.
If there is a whole slew of idle issues then I missed something.
Old May 8, 2018 | 10:10 PM
  #33
Monte4ever's Avatar
You are correct that is my problem. It idles just fine after the initial stumbling. I turn the key it fires then idles around 450-500 rpms then works it's way up. After 15 seconds or so (never timed it) it goes right to 900-1000rpms, as it's programmed to like a normal cold start.
Old May 8, 2018 | 10:24 PM
  #34
Kfxguy's Avatar
Well without me being there I was just suggesting a start over. I’ve had to do that because sometimes you make so many changes you forget what did what. If your running in sd mode, maybe that’s messing with it because it’s picking up the maf for a little bit. Your settings could be wrong for that. Do a search on how to put it in sd mode and make sure everything is correct. Maybe your diagnostic codes aren’t set correctly.
And check your startup flare spark. You could try making the startup flare less negative spark.
Sorry if i confused anyone, I’ll leave what I posted up because if someone is having idle issues, that process will help.
Old May 8, 2018 | 10:38 PM
  #35
JakeFusion's Avatar
Super Hulk Smash
Add timing on startup as well. 2-3 degrees. Spark > Cranking/Start. That helps. Just add 2 degrees across the board.
Old May 9, 2018 | 12:28 AM
  #36
Darth_V8r's Avatar
Moderator
Oh no, thats on me. I was just starting to question myself. Curious how tomorrow startup goes.
Old May 9, 2018 | 04:36 PM
  #37
Monte4ever's Avatar
Ok, here's what I did:
1. Added 2* timing to the crank spark table
2. Changed the IAC table to the figures Darth V8R posted and
3. Raised the MAF table's first cell from 13g/sec to 15
Car started as usual so my thinking was that it didn't have time to adjust to the new IAC settings so I cut it off after 20 seconds or so of idling. I waited for a few seconds and tried to restart it but it would not start. After trying 3 times I switched back to the original IAC settings and it started right up. IDK if this matters but the logged Idle Desire Airflow and the Dynamic Airflow was approx 50% off from each other with Idle Desire airflow being the lowest (7.19 to 15.53).
Old May 9, 2018 | 04:42 PM
  #38
Kfxguy's Avatar
What engine is this and what are your mods? What’s the cam specs? After you answer I’ll find something close to what you have in my files and see what I can send you.
Old May 9, 2018 | 04:50 PM
  #39
Kfxguy's Avatar
In the meantime try this
Old May 9, 2018 | 06:27 PM
  #40
Darth_V8r's Avatar
Moderator
Thanks for giving it a try. It was a bit of a stab in the dark without being able to read the file, but it did not do as I expected. After the car catches and idles, but while it's still cold, what is your dynamic airflow (not commanded airflow)? And, are you definitely SD or MAF?
The fact that your dynamic and commanded are so far apart, that tells me the IAC effective area table is off - likely still stock. But if we mess with that right now, it's going to continue to do what it is doing right now and possibly act worse.
