P0200 after injector swap
Old May 15, 2018 | 05:57 PM
black&blu's Avatar
Default P0200 after injector swap
I swapped to a new set of FAST 36# injectors. Changed the data in the computer took the car out to fire it up and it runs like crap and throws a P0200. I have put a new ground between the alternator and frame rail and a 4GA between the passenger head and the battery ground on the fender. After that, it will maybe idle right, maybe not. The one time I tried to take it out I didn't make the end of the block before it was running like total crap again. Going to try and put the 28# injectors in and see if it goes away tonight. Any troubleshooting post that? All of the injectors read between 13.4-13.6 ohms.
Old May 15, 2018 | 06:36 PM
black&blu's Avatar
Pin 1 and 40 on both the red and blue connector are less than .5ohms resistance to the battery....
Old May 17, 2018 | 12:03 PM
black&blu's Avatar
took the car around the block and all of the primaries are warm. Going to test each one for 12v tonight. Any other ideas?
Old May 22, 2018 | 06:41 AM
Old Geezer's Avatar
Data log?
Inj plugs on the correct inj?
