6L80E tuning guide
A very brief 6l80e tuning tutorial. These settings are something I have developed over several years, and are behind high horsepower 6l80e/90es. On the video I FORGOT TO MENTION, AFTER DOING THE PRESSURE CHANGES and once the tune is flashed, open the scanner and start scanning with KOEO (key on, engine off) and go to the VCM controls and special function tab, you have to click transmission reset then preset to make it go directly to your changes made. English is not my native tongue. lol
I've just got a stock 4.8 and 6L90e trying to make a nice daily driver in an old F150. I'd be lucky to be making 300 at the crank. I've just got lots of issues with surging when I'm stopped in D or R. But the trans does seem to shift at strange times and is reluctant to downshift at part throttle. I'm guessing this is mostly due to the 2.93 gears in the truck, vs the 3.55 that was in the van it came out of.
I'm not really sure if the surge is because of the trans, or in the engine tune itself. I found a pretty good gen4 idle tuning guide (can't remember if it was here or hpt forum) that I've been intending to try out, but haven't had the time to yet.
Like you said, it seems strange that with a totally stock engine and trans, that it's got all these driveability issues. I'm assuming I've either derped some setting, or something is wrong that I haven't figured out yet.
Ignore the WB on the log, my sensor died and I haven't got a replacement yet.
Thanks,
-Matt
what are your thoughts in regards to shift overlap when you modify the oncoming pressure offsets but leave the off going values as factory?
