Upstream and Downstream O2 sensors?
Old Jun 1, 2018 | 09:44 AM
Abdullah's Avatar
Default Upstream and Downstream O2 sensors?
Hello,
Is the upstream O2 sensor for measuring the A/F ratio of the burnt A/F mixture in the engine and to be tightened at the lower side of the exhaust manifold?
and
Is the downstream O2 sensor for measuring the efficiency of the catalytic converter and to be tightened after the rear part of the catalytic converter?
Thanks for help.
Old Jun 1, 2018 | 10:15 AM
Correct on both counts.
Old Jun 1, 2018 | 03:16 PM
Abdullah's Avatar
OK.
Thank you for help.
