Weird AC issue, Silverado
I am having a weird AC issue.
It has all new parts. New compressor, new Condenser, new accumulator, new low pressure and high pressure switch, new orifice tube, fresh recharge, no leaks.
The PCM will not cycle the compressor properly, it works on and off. When I connect tech 2 scanner, I see AC request signal to the PCM, I can see the compressor cycling switch closed yet, it says AC relay command - OFF
Here is a picture.
I have tried bypassing the low pressure switch, makes no difference plus the scanner correctly shows its operating properly.
I have tried bypassing the high pressure switch also makes no difference, when I unplug it it correctly shows AC request off, plug it back in I get AC request on.
It does cycle once in a while, and the AC is ice cold when it does, it just doesn't keep running for long. Since this is a 1999, that has a fixed compressor, is there some other crazy logic that makes the PCM not engage the compressor? I was under the impression that this is a simple analog system with low pressure switch that cycles the compressor and the high pressure switch to shut it off if pressure gets too high. Is there anything else I am missing that would make the PCM do this?
Truck tune, 1999 original PCM, truck was 4.8, just swapped to a 6.0, had 2 compressors, both the same, HU6 Delphi style, fixed compressor.
