Overheating coolant a swapped 07 ls2 c6 to ls3
Hi am having an issue with a swapped 07 ls2 c6 to an ls3 . Its overheating gradually on idle . Takes time till it overheats . Every thing seems fine in the car . I even tried to turn on the fans on high speed since I started the car to see wether it would delay or stop the overheating . But no help . I flushed the coolant and changed the water pump but still no help . Everything seems fine yet it's still overheating slowly and wouldn't drop even when the fans go to high speed . The car was tuned I guess by the previous owner . I haven't checked the tune yet . Do u guys think that it could be a tune related issue like high timing on idle . Or is there any thing Els need to be looked at . Thanks
The LS3 does not sit any higher than any other LS on the same mounts. The blocks are the same in that respect.
