2000 rpm idle in gear
I have a swap vexhile using the engine and trans from a 2006 trailblazer ss. The only engine mods are cai with a Colorado style maf, cats removed, elecric fans added. I had the pcm and Tcm tuned by a well known tuner via mail tune.
The truck starts and runs, it revs in park/neutral.
if you put it in gear and touch the gas pedal it will idle up to 1800-2000 rpm and you have to stand on the brakes to keep the truck from taking off. If you hit the gas pedal harder it will rev to 2500+ and idle there and I have to push the brake pedal through the floor to stop the truck. After the truck is complety stopped for 10 seconds the idle will drop below 1000 but it's still 700-800. The tuner says I need to drive it for a few miles to remedy this. I drive it slowly around the parking lot, but on the street this thing doesn' stop as the brakes are fighting the engine.. is this a tune issue or do I need to be looking at something else? No engine light no faults stored.
Thank you for any thoughts or suggestions.
I do have a scanner that can read the tbody position I'll bring it home tonight.
Somebody needs to verify the percent TPS is absolute Zero. Even one percent indicated TPS at idle will cause what you describe.
