red/blue or blue/green pcm
Old Jun 21, 2018 | 05:53 PM
81LS's Avatar
Default red/blue or blue/green pcm
Doing a LS swap in my 81 Z28 and wanted to know which PCM I should get. going to use a throttle cable, 4L80E, and will be running E85. I noticed there were two different PCMs out there and need to know if one is better than the other for running E85/FI/4L80E/DBC
thanks
Old Jun 21, 2018 | 09:13 PM
brandon6.0's Avatar
The red/blue is a cable pcm. The green/blue are dbw 2003+. Some dbw pcms from vans and v6 trucks can be made to work with cable setups. They are also usually flexfuel capable.
Old Jun 22, 2018 | 08:48 PM
Serioussn95's Avatar
check out this video Matt made. goes into a lot of detail but should help you understand the differences and what youll want to use. hope this helps.
Old Jun 23, 2018 | 12:35 PM
jayyk31's Avatar
Go with an 03 express van blue/green service #6106. It will be cable TB and 4l80e . I have one i was originally going to use but went with a 0411 due to being 6 speed..
Old Jun 23, 2018 | 03:14 PM
NSFW's Avatar
Originally Posted by brandon6.0
The red/blue is a cable pcm. [...]
It varies by car - my 2002 Corvette has a red+blue PCM (aka 411, P01), and the throttle is drive-by-wire.
Old Jun 24, 2018 | 09:33 AM
mcdonald77's Avatar
Do you want to run A/C? The blue/green some what complicates that if your building your own harness. There is no A/C signal wire like with the Red/blue. I know because I ised a blue/green. I had a trigger built in to the harness and triggered to run the fans on high when the a/c was on. My fans on high were loud as hell.
