3 bar SD TURBO tune, back to 1 bar N/A tune questions
Obviously, my brand new GM ZR1 3 bar MAP sensor will be worthless (to an extent), after the turbo is removed.
Is there any reason why I cannot just modify/TUNE my HPTuners 3 bar SD Custom OS to run the car Naturally Aspirated?
Injectors, Fuel system, Transmission, Engine displacement, gearing, etc....is all remaining the same...just the turbo is getting removed.
Should I just RE-TUNE the car, leaving the current OS intact?
Or, what?
I plan to remain SD, but instead of open loop, will probably run closed loop Speed Density...
I imagine if I decided to re-install a MAF, that I'd need to switch back to a 1 bar MAF OS?
Or, what?
I assume keeping the brand new GM 3 bar MAP sensor will also be fine? I remote mounted it when I got it, and since it seems to work much better than the 2 previous aftermarket versions, I really don't want to get rid of it.
That's what I was figuring/hoping. I just wanted to make sure there was no weird stuff going to happen, since nobody ever (by choice) goes backwards on power output...lol.
