Odd idle hang
Rick
throttle cracker, throttle follower and rolling idle airflow tables
base running airflow
base running airflow ECT multiplier
are all areas to look at.
rev hang is from too much air past the TB blade either through the IAC (which you can edit) or mechanically past the blade or through an air bleed in the blade. you need to find the happy medium of allowing enough air past for stable cold idle and stable return to idle in a dynamic operation, but not so much that the RPM hangs on coast.
personally I disable rolling idle and just use cracker, follower and adaptive idle strategies. most times I drill and air bleed in the blade. I set the throttle stop and relearn the 0% TPS point at the spot where I can maintain target idle RPM at operating temperature with 13.8-14.7AFR with only 8 degrees timing. that tells me that it will be very stable for warm idle and can add air with the IAC and timing with ECT corrections to return a stable cold idle.
I use that method and then tune cracker and follower tables in conjunction with adaptive idle to get the coast RPM, idle RPM and return to idle RPM transition to where im reasonably happy. then to fine tune it I use the idle spark table to add or subtract timing in the correlating RPM columns in the vacuum area (0.08-0.20g/cyl). if you have RPM hang on coast from 2000rpm back to idle. changing idle spark values from 25-30 degrees back to 10 degrees in the 0.08-0.20 area from 2000rpm to 1200rpm makes it return to idle RPM target quick smart. idle spark is your friend for fine tuning DBC large cam cars
see attached example for rough guide. its from a long time ago.
manual LS1 intake exhaust 232/234 .598/.598 112 cam. 3.46 diff gears
I’m about to get the mvpi 2 from hptuners. It’s odd as in it can warm up and idle all day and rev and come right back down but once you drive it it gets stuck in a hang. Just for peace of mind I have an entire new pcv system and new map sensor and throttle body gasket in the mail. After that I know short of intake leak it’s pretty much tuning issue. I appreciate the in depth help. I tinkered with my lt1 tuning but never with hptuners or obd 2 stuff. I’m going to get my iac counts into range of about 60 and then just disable the throttle cracker first though. If that doesn’t work then I’ll just find a 2000 stock ls1 tune file and start from scratch. Having a lighter flywheel doesn’t help me much either I’m sure
it has too much air for warm idle hence you have a rev hang. that same volume is correct for when its cold, hence its behaviour being correct.
your IAC is the only dynamic control over airflow at idle TPS. it only has a set mechanical range. if its completely shut it cant reduce any more air volume.
start from scratch with stock file is best to avoid tables you don't know are edited confusing you.
don't forget to consider timing values too as they can influence idle also. more timing increases coastdown/idle rpm less decreases.
if rev hang on coast down shows 30 degrees. changing that to 6 degrees will stop it.
I prefer cracker mode over rolling idle. I disable rolling idle and use cracker, follower and adaptive idle only.
However to the previous post the car will idle when hot. You can rev it all day but as soon as you take it out for a drive it will then start hanging. I think I’m going to try and disable all of the cracker tables and rolling etc and then if it doesn’t effect the problem at all then I think I’m getting into an issue of too much timing on coastdown? Is there a table for that? Coastdown timing??
also use the follower decay and delay tables to tune for your fault,
as far as spark goes you'll need to look at the tps and speed settings to enable or disable the main spark tables.
there is no coastdown spark table but coast down will be in the low air mass sections like 0.08-0.20g. edit either the main or idle tables in this area to help.
