Help P0158 and C0896
the C0896 code is the code the PCM has logged as a result of that fault. when you fix your open circuit fault to your bank 2 rear sensor and clear the DTCs it wont come back. C0896 is logged by the PCM because there is a voltage out of range/performance that may cause PCM damage.
