How to DATALOG LNC-2000 ignition retard on HPTuners
Thank you. I couldn't have done it without @shinanigans sharing his results and HPTuner formula...
Sadly, HPTuners forums suck as far as technical help, unless you are lucky enough to drag it out of someone, a half sentence at a time.
I'm having what I believe is a transmission setting issue on my 4L80E, and have had 100+ views, yet zero have looked at the attached tunes...
Thankfully, there's still people here who try to help.
I’m glad it worked out! I had no luck finding any info when I was trying to set it up as well.
Fwiw I’m pulling 8 degrees on a 150 shot on a stock ls1 and running low 10.80’s @123 full weight 3550 lbs. Still has A/C and everything, 4l60e with 9” rear. Sometimes it seems these motors like lower timing.
I am at 3885# with me in the car
sorry i missed this, did you get that sorted? i've been through my share of hassles swapping 80e's (but it's always worth it!)
Lockup and OD were set too low/too close to normal upshifts, so I guess it was confused...like it's owner is sometimes, LOL
Crappy weather has severely limited any driving, but last 2 times I took it out, it seemed fine.
Mine shifts great, as it should, since it is a Jake's D-3 Transbrake version, but the issue I have (hopefully, HAD), was when it was time to lockup in 4th, the transmission would freewheel, like the gear wasn't there...sometimes even did it on the 3-4 shift...
Funny you say that. I reflashed a much more conservative tune and although I wasnt able to put a "package" together yet, spun and went 11.43@123, then hooked (1.50 sixty) and nosed over in 3rd gear, lol. I am confident it'll go 10.80's or less next time.
Next try resulted in an implosion of the driveshaft, lol.
Decided to stop playing around, and swapped in a 9" and a chromoly driveshaft over the winter
Also swapped out the turbo spec'd camshaft, and swapped in a "Sloppy Stage 2" cam.
With a 150 shot, ran a new best of 10.69@125.6 with a 1.49 sixty foot, last weekend. 15 degrees timing, and a 1 second progressive hit.
Yesterday, put car on the dyno for the 1st time, just to make sure it was "safe"...
It was a Mustang chassis Dyno, which they say reads a bit lower than a Dynojet, but I was tuning AFR, not trying to get a number to brag about, lol.
348/356 NA, w/avg. 12.8:1 AFR, 22 degrees timing
448/442 w/150 shot, avg. 11.8:1 AFR (which is what I ran the 10.69 with), 15 degrees timing
504/520 w/200 shot, avg. 11.7:1 AFR, 15 degrees timing
No clue what the numbers would be at the crank (since I am running a 4L80 and a 9"), and/or on a Dynojet, but I'm good with the end results.
Have to re-do my LNC-2000 Timing Parameters as they no longer work for some reason after getting a new laptop...which is why I even came back to this thread, lol
EDIT: Had my "Actual Nitrous Timing" formula incorrect. Works great again...lol.
Had an = where the + is supposed to be...ooops
[14.161]-([30002.10]/.2)+.15
