Share a tune?
You'll need TunerPro to open it, but it's free. I'd post a link but I'm not sure that'd be allowed. You can google it though.
You'll also need the attached XDF file, and you'll have to change the file extension from .bin to .xdf after you download it.
Use TunerPro's "Select XDF" menu item to pick the .xdf file, then use File / Open to open the .bin file.
That .xdf is not a perfect match for that .bin, so if you see any tables that look like garbage, just ignore them. Most tables are correct though, and the ones the aren't right are pretty blatantly not right.
