Troubleshooting lean spikes on large throttle transitions
Engine management setup:
HP Tuners MPVI Pro
GM P59 ECU, drive-by-wire, basically complete 2005 GMC Yukon engine controls
2-bar SD operating system based on a 2005ish manual transmission 4.8L truck
GM IAT (no MAF) about 6" in front of throttle body
Injector Dynamics ID725 injectors, correct constants entered into the tune (for constant ~4 bar deltaP, see comment about FPR below)
Dual Walbro GSS342 pumps, -8 AN feed, -6 AN return. Second pump on low-pressure Hobbs switch, first pump always runs full speed
Engine:
370 ci LQ4/9 derived engine
~9.5:1 CR
PRC 225 as-cast cathedral port heads
TSP 228/232, .600", 114 LSA + 3 cam
LS6 intake manifold
LS3 Camaro exhaust manifolds
Turbonetics T-Series 7875 .96 A/R T04 turbo
Very free flowing exhaust after turbo
Manual transmission (T56 Magnum)
Symptoms: On rapid throttle transitions, such as you might encounter when shifting the car quickly, there is a major lean spike reported by my wideband O2 sensor. It sometimes causes a misfire that can be heard and felt. It is possible to do this by whacking the gas pedal at idle.
To the best of my knowledge, the car is correctly tuned for steady state operation. I don't have any big "holes" in the VE map, fuel trims are typically <5%, and the car tracks close to target AFR at WOT.
Possible quirks in the tune:
- I'm running a pretty late end-of-injection timing to reduce fuel short circuiting with the cam.
- Burst knock retard is effectively disabled
What I've tried:
- Disabling DFCO by setting the temperature thresholds really high.
- I played with the two transient fuel tables I can see (which appear to be gain tables, not the actual impact table) but it didn't seem to do much.
Suggestions are welcome.
Anything else?
