boost enrichment?
Old Jul 17, 2018 | 11:02 AM
Thumpn's Avatar
Default boost enrichment?
I am running os 3 bar SD, my question is If i am running a boost ref reg w/ return Do i want to turn off the boost enrichment?
Old Jul 17, 2018 | 11:15 AM
ddnspider's Avatar
they have no relation. The only thing you change when you have boost reference on your FPR is you flat line the injector flow rate table instead of sloping it.
Old Jul 17, 2018 | 10:02 PM
epfatboy's Avatar
Do you flatten the injector flow table using the using the max or min value?
Old Jul 17, 2018 | 10:19 PM
Thumpn's Avatar
minimum value
